Failed to mount media drive
  • August 29, 2022
  • 7 replies
  • 4815 views
Forum|alt.badge.img+9
Hello, Team
I am getting the error below on majority of jobs running.
I have checked the storage end and also the media agents (The LUNS are attached to the Media Agent) Everything looks good.
What could be the cause of the error.
Failed to mount the disk media in library [ARCHIVE_DISKPROD] with mount path [B:\Archive_DiskLibrary\MP10] on MediaAgent [hq_media_svr3]. Operation could not be completed in timeout interval. Please check the following: 1. Library and drive is functioning correctly. 2. Library and Drive management services are running. 3. All other MediaAgent services are running. 4. The time out period on the Expert Storage Configuration Properties Window in the CommCell Console. 5. Cleaning media in Assigned Media Group. Source: hq-vm-commserv, Process: MediaManager
Hello @Mubaraq
The error could mean a few different things but is especially concerning since the mount path is local storage. Essentially the OS is reporting it tried to perform an IO operation on the storage but the operation took too long and the write timed out.
Can you confirm the hardware is healthy? I understand it is connected and accessible but is Windows or the array hosting the LUNs reporting any errors? Also can you confirm if AV exclusions are in place?
Recommended Antivirus Exclusions for Windows - https://documentation.commvault.com/11.23/expert/8665_recommended_antivirus_exclusions_for_windows.html
Thank you,
Collin
  • August 29, 2022
Hello @Mubaraq
Also try to increase the mount and unmount values to see if it helps.
Right click on disk library and you can find mount and unmount timeout settings.
Please check media server system event viewer when this error is reported by commvault. This may give you clue on what may be wrong.
  • August 30, 2022
Hello, guys
So, we tried all of those and it is still same issue.
We have raised a support ticket.
Case ID is, Incident 220819-155.
Can someone help follow up, please?
Hey @Mubaraq,
I had a look at the case and the logs. Could you try restart the services on the CommServe? there is something very strange happening with the MediaManager process.
Basically the Media Agent is sending a request to the CommServe/Media Manager process to allocate it a chunk/volume - basically a unique number that will be used to store data in for the job. Although it looks like it receives the request, it is not being processed.
In the second column of the logs is the ThreadID (2874). And what is interesting is that this thread is the only one reporting this issue. So I think perhaps Media Manager is stuck somehow, and a restart of the CommServe services may help.
16736 2874  08/25 22:25:45 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3068522] TIMEDOUT AFTER [653] SEC.
16736 2874  08/25 22:26:45 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3068901] TIMEDOUT AFTER [653] SEC.
16736 2874  08/25 22:31:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3071027] TIMEDOUT AFTER [649] SEC.
16736 2874  08/25 22:35:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3072386] TIMEDOUT AFTER [653] SEC.
16736 2874  08/25 22:56:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3080823] TIMEDOUT AFTER [640] SEC.
16736 2874  08/25 22:57:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3080976] TIMEDOUT AFTER [643] SEC.
16736 2874  08/25 23:04:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3083428] TIMEDOUT AFTER [639] SEC.
16736 2874  08/25 23:06:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3083831] TIMEDOUT AFTER [637] SEC.
16736 2874  08/25 23:10:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3084986] TIMEDOUT AFTER [621] SEC.
16736 2874  08/25 23:11:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3084996] TIMEDOUT AFTER [676] SEC.
16736 2874  08/25 23:27:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3092545] TIMEDOUT AFTER [634] SEC.
16736 2874  08/25 23:28:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3093908] TIMEDOUT AFTER [631] SEC.
16736 2874  08/25 23:36:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3103069] TIMEDOUT AFTER [627] SEC.
16736 2874  08/25 23:37:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3103838] TIMEDOUT AFTER [621] SEC.
16736 2874  08/25 23:41:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3105388] TIMEDOUT AFTER [630] SEC.
16736 2874  08/25 23:42:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3105622] TIMEDOUT AFTER [624] SEC.
16736 2874  08/25 23:58:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3111885] TIMEDOUT AFTER [624] SEC.
16736 2874  08/25 23:59:46 -------  SCHDLR   [        ]  *** REQUEST [REL100_MM_RESERVE_MOUNT_VOL_FOR_DRIVE_REQ] RID [3112234] TIMEDOUT AFTER [623] SEC.
  • September 3, 2022
@Damian Andre thank you so much for your input.
We have restarted the services on the commserve, the error persists. We also went as far as killing the jobs and restarting them.
What else would you suggest, please?
  • September 3, 2022
I have seen an issue in the past where we were having a lot of  retries on an S3 LUN. This caused the media mount service to hang which stopped mount paths on different storage from mounting.
Hi to all of you, something similar here
We had an issue last week when trying to upgrade from 11.24.48 to 11.28.24. I had done a vmware snapshot of the commserve before the updrade, which didnt go well and I finally did a revert and the worst happened, both Media Agents DDBs’ went corrupt. We were able to do a reconstruct, but I started to see the following message about the same time….
Failed to mount the disk media in library [TDC1-MA03-DAS] with mount path [C:\CVDisklib\CVlib2] on MediaAgent [stdc1bckma03]. A mount path already exists at the given location. Please enter a different mount path.
I did try to either restart the commserve services and the machine itself, same for Media Agents, no success
Any other suggestions?
thx in advance
