Failed to read media during restore
  • November 23, 2021
  • 9 replies
  • 4531 views
Hi everyone
This is my first post.
I was trying to restore some files I lost from an earlier backup.
I could view the files and folders. I selected the copy precedence to be 1 (my primary copy)
However, whenever the operation starts, it gives the error “Failed to read media during restore” and stops at 5%
Everything seems fine. Until I tried to skip the errors, and I find out that the folders are restored, but no files in them.
Please help out. Is there something in the settings I have to change?
Best answer by Mike Struening
@zadok001 , were you able to get this working?  Seek errors are usually indicative of hardware issues (either connecting to its resources or with the device itself).
MichaelCapon
  • November 23, 2021
Hi @zadok001 ,
What Agent type are you restoring from here please? - Windows/Linux FileSystem, VSA, etc.
It would be worth checking the logs for this one, One the Job you can “View Logs”. - Depending on the type of restore here will depend on what logs are necessary/displayed.
If the Primary is on Disk, Do you have a secondary copy of the data? - If so, are you able to restore from that?
Michael
  • November 23, 2021
Hi @zadok001 ,
Michael
Thanks Michael.
Agent Type is Windows FileSystem. What exactly do I look out for in the logs?
Secondary copy is not available.
MichaelCapon
  • November 23, 2021
Thanks @zadok001 ,
Since this is WinFS we will need to look at CVD.log on MediaAgent for any related communications or read errors. On the Client Machine we’ll need to likely check the ClRestore.log file for anything on client side.
Have a look in those logs and let us know if you spot any issues.
Note: If you have trouble with the logs, we do have the GxTail util (In /Base/ folder) which you can use to open the logs, Filter (F5) on the JobId and place Markers (F9, Select a profile) for highlighting errors.
For details on the tool see here: https://documentation.commvault.com/11.24/expert/49881_gxtail_overview.html
Michael
  • November 24, 2021
Thanks @zadok001 ,
Michael
Thanks Michael
So I checked the logs (cvd ON Media Agent, CIRestore on the Client) I found this error to be recurrent, “the failed byte count does not include files that failed due to seek error”. I attached a screenshot. Now the major issue is that “seek error”. This is what I got on the Commserve.
Forum|alt.badge.img+16
  • November 24, 2021
Hi and welcome @zadok001
BTW, were you using deduplication on the backup ?
Is the storage used for this primary safe ? I mean not corrupted and fully available ?
@zadok001 , have you had a chance to review @Laurent ‘s questions?
  • March 21, 2022
We recently ran into this issue.
Let me back up a second.
The dimm for the controller card on the server went out - we ordered and replaced it.
System came back up without any issues - then we had a restore request post hardware update.
Haven’t reviewed the logs yet - however ordering the secondary copy (thankfully we have one) to see if I can do a restore from tape.
@camador , kee4p us posted!  If you run into issues afterwards, I’ll move this to its own thread for better tracking :nerd:
