Hi guys,
I’m struggeling with encryption in a mixed environment.
On the GlobalDedupePolicyCopy, I did not activate encryption.
on the Client Advanced Property I enable encryption
on the subClient Property I enable encryption on Network & Media.
executed Jobs are listed as ecryption enabled.
- does this mean, that the backups have been encrypted ?
- are the backups deduplicated against unencrypted backups within the same StoragePolicy ? (which might result in a mix of encrypted and unencrypted data for the same job)
- Since encryption is defined in the GDP and I already have two DDB partitions per MediaAgent, do I have to deploy additional MediaAgents to host the dedicated encryption backups, in case I want to enable that on the Storage Policy ?
best regards
Klaus
Best answer by MichaelCapon
