how to restore a file deleted from a fileserver
  • November 2, 2023
  • 118 views
i would like to know how to restore a file deleted from a fileserver
Thanks.
Chris Hollis
  • November 2, 2023
@Storage a file deleted
Java Console Instructions can be found here: https://documentation.commvault.com/2023e/expert/18554_restoring_data_using_windows_file_system_agent.html
If you are using the command center, instructions for that are here: https://documentation.commvault.com/2023e/essential/86723_performing_file_system_restores.html
Chris
SparshGupta
  • November 3, 2023
Hi @Storage a file deleted
You can perform “Point in time restore (Look for the specific date and time when the file was still available)”, and then select “Show deleted items” checkbox, and recover the deleted file back.
Sparsh
