Library cleaning tape procedure
  • August 25, 2021
  • 779 views
Fernando Souza
Explorer
The customer has purchased a tape library Fujitsu LT20.
Is there an automatic tape cleaning procedure?
Best answer by dude
You can schedule the cleaning on a regular basis as needed.
Refer to:
Schedule Drive Cleaning: https://documentation.commvault.com/commvault/v11/article?p=10118.htm
dude
Forum|alt.badge.img+20
  • Community All Star
  • August 25, 2021
Refer to:
Fernando Souza
Explorer
Hello @dude
I will see and make this configuration on the customer.
Thanks.
