We are trying to move a mount path to a new media agent, but it’s failing ever since we stopped the job. The disk became full resulting the data migration job being stuck for weeks, so we stopped the job and freed up space. However, every time we try to restart the mount path move it fails.
We did the following to troubleshoot:
- Run disk defragmentation
- Verify disk and mouth path are online
- Validate mouth path
- Verify no disk maintenance task is running
- General sanity checks
The error that we get is:
Move Mount Path Job Failed, Reason : The mount path is under maintenance and hence cannot proceed with the move operation. Source: <MediaAgentName>, Process: LibraryOperation
Can anyone tell how to fix this error? How do we get Commvault to see that the disk is not in maintenance mode?
