My daily incremental DDB Verification job uses more than the max streams / readers
  • September 20, 2021
  • 602 views
Forum|alt.badge.img+20
Hi !
I’ve noticed a strange behaviour of a daily DDB incremental verification job, normally set to 30 readers, but getting much higher than this since a few days..
See below
How can this be possible ?
I thought that the limit was.. a limit :grinning:
So, what has changed ? Well, not sure it is related, but since sept9, I upgraded from v11FR21HP20 to v11FR21HP53, and no other change.
The Gridstor of 4 hosting this DDB also host another DDB, whose verification job runs without getting (or printing only) the maximum 30 readers limits.
That’s a bit annoying because the first job goes pending for a while with :
Error Code: [19:1105]
Description: No Resources Available. Please check the Streams tab for details.
Of course no ressources are available, as it’s trying to allocated more than 30..
A few details about this job and blocks to process :
Should I log a case or, have you already been used to such ?
Best answer by Damian Andre
Hey @Laurent,
This one had me stumped. Turns out, we recently detected this issue and a hotfix is available. I’ll send you the download link via PM - it will be fixed in maintenance release 59 and above, but I’ll send the link for the hotfix on top of maintenance release 58.
Hey @Laurent,
  • Challenger
  • September 21, 2021
Thanks @Damian Andre , now I plan to apply FR58 +hotfix this thursday afternoon.
Coming from you I guess I can consider this topic as answered :wink: .
