Problem with Tape Library
  • May 30, 2022
  • 152 views
we use an “Fujitsu Eternus LT S2 10” with our commserve and till we change the StorrageLibrary it works good. But now we get this Message and I doesn’t find the right setting to activate the tape-Library.  We use  11.25.23
Can you help me ?
best regards
Chris
Best answer by MNCHR
We’ve succeded the problem, it was an network connect problem. Now it run.
Forum|alt.badge.img+20
  • Challenger
  • May 30, 2022
Hi @MNCHR ,
To make sure I understood well, this tape library has been replaced by a same one, on the same ntbackup4 server ?
If so, has it been done hot, without rescan, or reboot after the operation ?
If it’s the case, maybe the SCSI ID has changed between the 2.
You could also go to Expert Storage Configuration, select that MA, and try to configure/reconfigure/detect, depending on what you see (and your level of trust / knowledge of that part 😉), else don’t go too far or you could have to reconfigure many things.. 😄
  • May 30, 2022
Thank you for your prompt reply. No, it's an existing tape library. According to my colleague, a new storage system was used and the tape library was only technically connected to the network with a "little leg". I suspect this is the problem.
Can I also activate the "Solid Stade" manually?
regards
Chris
  • June 1, 2022
Thanks for the update, @MNCHR !
