pruning is disabled on MA
  • Nov 7, 2023 8:16 PM UTC
  • 234 views
my backup storage has filled up rather quickly. I set up a blackout window for pruning after aging some of the older backups but, the SIDBPrune.log shows “12724 34c8  11/07 15:08:01 ### PRNCTLR StartPrunerThreads:4536 Not starting any pruning threads as pruning is disabled on MA” . I believe i have enabled it in every place i could find. could anyone provide me a list or point me to an article showing all the locations this could be enabled/disabled from?
Thank you
Best answer by Abhishek Narulkar
Please also check if the option “Enable pruning of aged data” is enabled on the mountpath. Follow this doc link
https://documentation.commvault.com/2023e/expert/9369_enabling_aged_data_pruning.html
Scott H
  • Nov 8, 2023 11:13 PM UTC
Thanks for reaching out for assistance here.
You can check that pruning is enabled by following the 2 document links below:
https://documentation.commvault.com/2023/expert/8876_enabling_or_disabling_data_pruning.html
https://documentation.commvault.com/2023e/expert/12530_disabling_physical_pruning_of_data.html
If there is still an issue thereafter may I please recommend you raise a case with our Support so we can review and assist accordingly.
Kind regards,
Scott.
