Questions about configuring immutable copy on azure and worm protection in commvault
  • Jul 3, 2024 9:27 AM UTC
  • 131 views
Hi All,
Our environment is a mid size enterprise setup, we have around 250 servers hosted on On-Prem and Azure. We have configured sync copy to azure with retentions of 10 years for the On-Prem servers and for servers on Azure we have just 1 copy of backup. We would like to have immutable copy on azure and worm protection in commvault. It would be really grateful if anyone can list down the steps and precautions to be taken along with price calculator.
We would like to have a weekly full backup with 14 days retention and 2 cycles on this copy.
We would also like to know if deduplication is supported? and what preferred storage type (Hot/Cold) on Azure is preferred.
Can we use existing media agent which is being used for Sync copy to perform the copy on this selective copy?
Does this solution offer a complete end to end protection from cyber attack/ransomware?
Hello @CVEngineer
Thanks for the question and details but this is a very advanced question is pricing and design.
I recommend engaging your account manager to get PS engaged to assist with a design.
In regards to your Dedup and such questions on WORM storage the following goes into it:
https://documentation.commvault.com/2023e/expert/configuring_worm_storage_lock_01.html
Kind regards
Albert Williams
Hello @CVEngineer
Kind regards
Albert Williams
