Looking to start a replication group from a VM and default backupset to a mount path on a dell powerscale. Going forward this volume will be san hosted instead of mounted via a server. Upon looking at the config- i dont see an option. Im away replication groups are agent to agent. I thought about makign a library with the location- but even that doenst allow.
Answer
replication group to dell powerscale
Best answer by Jos Meijer
Am I interpreting correctly that you want to replicate the VM files from a hypervisor (backup) to a non-hypervisor related storage location?
If so, the replication group is only capable (as far as I know) to replicate between the same environment types.
hypervisor to hypervisor
file agent to file agent
database to database
