Reporting CLI
  • April 18, 2023
  • 126 views
Good afternoon,
I am trying to create a report on the occupancy of our libraries. However, the report coming from Commvault has a lot of information.
Would it be possible to use CLI to extract only the information I want?
My idea is to create a script and run it every month without having to manually organize the data.
Best answer by Damian Andre
Rather than using CLI (where you might be able to find what you want here) - it may be more beneficial to use powershell to call our REST API - which is way more documented and has more information than the traditional commvault CLI interface.
The full list of rest api is available at https://api.commvault.com
The other option is to build your own reports with the custom reports engine:
https://documentation.commvault.com/2022e/essential/44561_build_your_own_reports_overview.html
  • April 20, 2023
