Secondary Copy To Tape - Content Indexing
  • February 11, 2021
  • 570 views
I am hoping someone can direct me in the right direction.
I have a secondary copy to tape with an infinite retention period. The tapes will be stored offsite for safe keeping, currently tapes are onsite. I noticed during restores of older data I would need to insert the tape media containing the index to browse content to restore.
Is there a way/method to keep this index on a local storage so the tape is not needed to browse the contents?
Best answer by dude
From what you are describing it seems you are using Indexing V1. So from  what I know you would really have two options which the first one would be to upgrade your clients to Indexing V2  (Upgrading Clients to Indexing V2) and if that is not an option right now, you can build a Secondary Index Server.
For Secondary Index Server refer to: https://documentation.commvault.com/commvault/v11/article?p=10715.htm
The indexing retention service for V1 will run every day and clean anything older than 15 by default. You can configure the retention as well, see the link https://documentation.commvault.com/commvault/v11/article?p=10713.htm
Index Version 1 Diagram https://documentation.commvault.com/commvault/v11/article?p=10709.htm
Index Version 2 Diagram https://documentation.commvault.com/commvault/v11/article?p=10774.htm
I`m just a CV user, there are some Pros here that im sure can shine a light to you as well.
Hope that helps.
dude
Forum|alt.badge.img+18
  • Community All Star
  • February 11, 2021
Hope that helps.
  • February 11, 2021
Some users in the past created much larger index cache repositories for specifically this purpose.
You would essentially have a much larger index cache directory on a dedicated MA (say 10-20TB) and configure extremely long index cache retention for this MA. This way when you use this MA for restores etc it would only need it once and essentially attempt to keep available forever. You would need to remember to do a browse for each job using this MA before tapes go offsite so that indexes are populated to this MA.
But yes, best way forward would be V2 indexing where the new index DB will contain everything needed for a subclient/backupset level rather than individual jobs for V1 indexing.
