We noticed on a RHEL8.7 build with a local disklib & ransomware enabled that it breaks xfs utils.
Opened a case with RH support. They said for mount options “try context=unconfined_u:object_r:user_home_dir_t:s0” instead of the recommended “context=system_u:object_r:cvstorage_t:s0”, which does fix the issue with xfs commands. Now they are asking me to ask you all do other customers have the same experience? Or, they suggested use the context that “allows xfs to work” to which I replied “I have no idea but this is what the script sets up”.
Basically if you setup a diskib using xfs (not NFS or S3 obviously), simply try to run xfs_info or xfs_growfs, can’t be done. The workaround I found if I need to grow the FS is stop service, remount without ransomware context in place (or use their options), fiddle with xfs, then remount with proper context. Looking for some way to fix rather than workaround but they seem firm in “it’s not a problem” with selinux or xfs, it’s the way it’s mounted.
thanks
