Separate T-Log from copy to Auxiliary Copy
  • August 25, 2021
  • 168 views
Hi All
i have a question for the expert's :)
we using Metallic Storage for secondary copy.
we backup SQL Instance’s there, with T-Log (lot of jobs) and Daily Full.
i want to ask if i can somehow to exclude only the T-Log from going to the Second copy.
i want only the Daily Full will go to the Auxiliary Metallic Storage.
is it possible? (without create a new policy of course).
thanks in advance
Best answer by Sunil
Hi @Avior,
1: The selective copy doesn’t help if you need incremental backups also to be copied. In your question you mentioned you need the daily fulls, so the selective copy option is appropriate for it.
2: You can edit the current secondary copy. You need to select the “Selective copy” check box in the General tab to enable the Selective copy tab.
Sunil
Sunil
Forum|alt.badge.img+13
  • August 25, 2021
Hi @Avior
Did you try selective copy? You can copy only the FULLs (all fulls, hourly, daily, weekly, monthly etc) using the selective copy to the second copy.
https://documentation.commvault.com/11.24/expert/13909_getting_started_with_selective_copies.html
Sunil
  • August 25, 2021
Hi Sunil, thanks for your response.
the thing is that:
  1. Primary Copy include SQL and vMware subclient that contain few machines.
and from that subclient we need to incremental and the full backups..so if i will use the selective copy option it will not take the incremental’s
  1. there is a way to edit current Secondary copy? because the Selective Copy is greyed out and i cannot touch it , even if i want edit it.
thanks
Sunil
  • August 25, 2021
Hi @Avior,
Sunil
  • August 25, 2021
thanks again Sunil
and for to original request..there is a way to exclude all the T-Log from Auxiliary copy without create new storage policy?
Sunil
  • August 25, 2021
We can associate a different storage policy for log backups which doesn’t have a secondary copy to Metallic storage.
I am not aware of any other way. May be there exists but I’m not aware.
Sunil-
