Snap copy to Server Plan
  • September 29, 2022
  • 191 views
Nikos.Kyrm
Forum|alt.badge.img+16
Hello CV community!
I see that from 11.24, you can add snapshot copies to server plans.
https://documentation.commvault.com/v11/essential/139040_new_features_for_snapshot_management_in_1124.html
Im not sure, this snap copy in supported only with specific type of storages?
Does anyone actually use it ?
Please for your feedback,
Nikos
Best answer by Jordan
Yes, you need a snap copy in order to store/manage IntelliSnap backups. Previously this was only available via Java Console, feature enhancement you mentioned is just adding it to Server Plans in Command Center.
Hi @Nikos.Kyrm
Here’s the list of storage arrays supported by IntelliSnap.
https://documentation.commvault.com/11.24/essential/106164_supported_arrays_and_agents.html
Nikos.Kyrm
  • Community All Star
  • September 30, 2022
Ok, so Snap Copy & IntelliSnap is actually the same feature ?
