Storage Engineer
  • 27 March 2022
  • 51 views
Badge +1
I’m currently performing backups of Azure Fileshare for a subscription using Commvault. The backup is being performed in one Azure region and customer wants to restore the Azure Fileshare to another region.  What do I need to do perform that type of restore in Commvault?
Best answer by Damian Andre 28 March 2022, 01:40
Badge +15
Good morning.  Here is the documentation on restoring the Azure data out of place:
https://documentation.commvault.com/11.24/essential/135786_restoring_object_storage_repository_out_of_place_05.html
If you are restoring to a different repository, then you may need to configure that following “adding object storage repository”:
https://documentation.commvault.com/11.24/essential/115084_adding_azure_file_storage_object_storage_repository_01.html
You probably need to deploy another proxy / client access node to conduct the restore local to the religion you want to restore to, rather than trying to use the same one in a different region that took the backup. Either way you are likely to incur egress charges since you are taking data from one region to another.
