Hello
Following the Commvault SE recommendations we have created a storage pool of 4 Media Agents with DAS storage. Initially all MAs could read and write data to each mount path and I have noticed that the "lan-free" logic does not work. I mean, each MA tries to access each mount path even if "closest" or fastest way available. Despite our network is 10Gb, data transfer between MAs is slow, very slow. Now, I have allowed only reads for any MA for any path and it works better, but still not perfect. The most important fact that aux copy to tape is very slow. Each policy allows each media agent access to any tape so my idea was "ok, let's stop access via IP and only MA that has its DAS will read/write data". So, backups are fast, aux copy is.... failing! Because MAs couldn't access data on another MAs.
So, I am stuck with no ideas, except that stop using Storage Pool and go back to use each media agent as standalone.
Any ideas how to:
- have a storage pool
- force each MA to use their DAS only
- force CV to aux copy using all MAs, so if block1 is on ma1 - it will be written by ma1 to tape, if block2 is on ma2 - it will be written by ma2 to tape.
Suggestions?
Best answer by Roman Melekh
