Tape library is not displayed correctly, only the drives are seen individually
What will be the problem?
Has this worked before, or is this a new library just being added?
It is a library that has just been added.
Can you please run a detection on the library and provide the results?
Hi Juan,
Happy new years!
Is this 1 library with X amount of drives shown as 4 different libraries correct?
If so, this will likely be an issue.
Which operating system is hosting the library? Windows, or unix?
