The path doesn’t have sufficient space to perform a DDB backup
  • September 27, 2022
  • 1415 views
I have installed Linux MA with RHEL 8 OS and attached a 2.9TB NVMe Disk  formatted using LVM and divided In equally into two partitions (1.4TB for each one ) when trying to add storage pool and specify DDB path I get an error (The path doesn’t have sufficient space to perform a DDB backup) although no data written yet
NVMe Partition with no data
Best answer by Iggy
There needs to be a free number of extends in the Volume Group where the DDB Logical Volume is created.
As the KB and documentation suggests leave about 15% free capacity in the Volume Group.
Disk = 100GB
Volume Group= 99GB
Logical Volume = 85GB
Hope that helps.
Ignes
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
Hope this helps 🙂
https://kb.commvault.com/article/67762
Contains info related to creating the DDB partition, but also reflects on DDB backup failing
Hope this helps 🙂
I already know that KB but I don’t get it when the format of the NVMe disk makes unallocated space around 50 GB
  • September 29, 2022
Disk = 100GB
Volume Group= 99GB
Hope that helps.
Ignes
