Total Data Size on Disk is zero
Forum|alt.badge.img+2
Newly created DDB engines shows application size as 800 TB and Total Data Size on Disk as zero.
Same issue with few newly created DDBs. we are on V11.28.56
Hi @Sajeed ,
Can you confirm if you are using the Local, Remote Java Console or the Command Center please?
Can you try the other methods?
I am not sure if this is just a GUI/Display issue.
Are you able to log a case with Support so we can check and confirm?
Let me know
Sebastien
  • Byte
  • May 16, 2023
Hi @Sebastien Merluzzi I have tried Local and Remote Java Console still the same, I do not see an option in command center where I can see DDB engines
ok,
I am not sure if this is just a GUI/Display issue. I cannot find any issues.
  • Byte
  • May 16, 2023
We do not have direct commvaut support, will check with 3rd party support.
Cookie policy
Cookie settings
