We have a partitioned DDB that uses a Disk library with 12 mount points. Spill and fill has been configured.
An oracle DB is backed up with 4 streams/channels. The backup allocates 4 streams but these streams are allocated to one mount point and via one MA.
How can the streams be spread across multiple mountpoints such that 2 go via MA1 and 2 via MA2.
Second Oracle DB is being backed up. This takes the same partition as the above job and uses another mount point with all 4 streams going to the same mountpoint.
Any ideas how the streams to make Commvault distribute the streams evenly?
Best answer by neuwiesener
