For data security I was told to do search on the WORM option at Primary copy level of our storage policies..
Just a bit of background of our environment, we have short data retention set on our Primary Copy - 35 days 1 cycle. My understanding is that this WORM option in storage polices work within Commvault software and no admin(or anyone) can delete backup jobs after it is enabled, and we have to wait for job to age out and then be pruned by commvault automatically.
Then I was advised that if I enable WORM, DDB for its storage policy will be sealed. A new DDB will be created automatically after rebaselined. So I have some questions below.
- is DDB sealing an automate process? i did enable WORM option more than a month ago for a storage policy for testing but I cannot see a sealed ddb under ‘Deduplication engines’.
- Our disk libraries are quite big (from 300 TB to 800TB). if we need to do the rebaseline every time, will this take long time and have impact on performance?
- With only 35 days 1cycle retention set for Primary copy, do we need to seal DDB? What is the purpose of sealing a DDB? I was told that there is micro-pruning involved to reclaim space back but I dont really know how it works and how WORM option will have impact on it.
Any idea or feedback would be greatly appreciated.
Thank you.
Best answer by Niall
