What to do after losing backup storage
  • December 17, 2021
  • 16 replies
  • 946 views
Ken_H
Apprentice
Hello everyone,
My secondary site has a Windows server connected to HPE MSA disk shelves.  Earlier this year we added another disk shelf but my storage admin now tells me it’s improperly configured and he wants to correct it which will result in the lose of all the files on that individual shelf.  The storage appears to CommVault as J: (51TB), K: (51TB), L: (51TB), and M: (18TB).  It is just the M: allocation that needs to be corrected.
All backups have two copies with one at my primary and one at my secondary site so I *should* be able to re-copy the affected backups over to the secondary site once the storage is fixed.  Does anyone know if there’s a procedure or web site that shows how to do this?  It would be the equivalent of recovering from an disk failure.
Any help would be appreciated.
Ken
Best answer by YYZ
Do you have all 4 Drive Letters providing Mount Paths to a Single Library?
If you have free space on the  3 lots of 51TB (enough so the capacity of the 18TB mount paths can fit) you could move the mount paths
https://documentation.commvault.com/11.24/expert/9302_moving_mount_path.html
As per the documentation - allow 24 hours and the ‘source’ mount paths on the 18TB should clear down to zero
@Ken_H , is there any parity on the drives so you can replace and rebuild it at that level, or is this not RAID, just a drive presented?
You could Aux Copy all of the data off, ensure the jobs are there, replace the disk, then Aux Copy it back (and promote the disk copy back to Primary).
That’s likely your easiest and cleanest method.
Ken_H
Apprentice
  • December 17, 2021
@Mike Struening, This is my secondary storage and all backups are configured to have a copy on both the primary and secondary media agents.  It sounds like all I’d need to do is re-run an aux copy from the primary media agent.  How would I ensure that all backups are fully replicated after the change?
Ken
Oh, even better!
Beyond normal restore testing after completion, you could (afterwards) set the retention on the current copy to Spool Copy.  This will only allow jobs to prune once they are fully copied over to all dependent copies (there’s no days or cycles count).
If the source copy clears out, then you’re good.  If any jobs remain, then the Aux didn’t complete (or there are other issues).
Of course, worth repeating that it pays to do some quick browsing/restore testing JUST to be sure!
YYZ
Novice
  • December 17, 2021
Ken_H
Apprentice
  • December 17, 2021
@YYZ, the documentation for Move MountPath says “Do not move a mount path to another active mount path” so I’m not sure this will work for me.
YYZ
Novice
  • December 17, 2021
That's correct. You cannot drop an existing mount path within another mount path.
You would have to create new/empty folders
Ken_H
Apprentice
  • December 17, 2021
I tried a little experiment to move everything off M:.
  1. Update M: to “Disable mount path for new data”
  2. Went to Storage Policies > Email > Copy 2 > View > Jobs > Job 388543 > right-click > Delete job > erase and reuse media > OK
  3. Right-click on the Commcell > All tasks > Data aging > immediate > OK
  4. Back to Policies > Email > right-click > Aux Copy > OK > waited for job to finish
  5. Client > Exchange Mailbox > right-click > View > Archive history > OK > highlight job 388543 > right-click > View Media > only shows the copy at my primary site.
So … the aux copy did not replace the backup I manually deleted on to a different drive.  That’s unfortunate.
Ken_H
Apprentice
  • December 17, 2021
@Mike Struening  I don’t see anything on the properties of Copy 1 in the storage policy for a “Spool Copy”.  I’m not sure where you’re getting that.
@Ken_H , I should have been more specific.  Spool Copy is a setting on the retention tab for any copy that has dependent Aux Copies.
This should help:
https://documentation.commvault.com/11.24/expert/119069_spool_copies.html
Let me know if you have more questions!
I may be missing something, though for Spool copy you need to let the job Aux copy over before it gets deleted.
Ken_H
Apprentice
  • December 17, 2021
The Enabling Spool Copy page says:
  1. ensure that the storage policy copy is assigned as a source to another active synchronous copy.
  2. From the CommCell Browser, go to Policies > Storage Policies ><Storage Policy>.
  3. Right-click the storage policy copy that was assigned as a source, and click Properties.
  4. In the Copy Properties dialog box, click the Retention tab, click Spool Copy (No Retention), and then click OK.
But when I go to Copy 1 > Properties > Retention tab, there is no Spool Copy option.  Sigh.  If I had a dollar for every time the user interface didn’t match the documentation, I would be a very rich man.
Ken_H
Apprentice
  • December 17, 2021
Thanks everyone for your help.  It seems clear that this is so far outside the normal bounds of what can be done with CommVault that I’ve opened ticket 211217-687 to get some assistance.
Ken
If it’s not there, then maybe there’s no Synchronous Aux Copy yet?  I’m darn curious now!
Once you have an answer, let us know.  The main issue is of course your concern, though the not-appearing-spool-option is curious.
Ken_H
Apprentice
  • December 17, 2021
Ignoring the two most recent aux copy jobs that I ran manually today, you can see that aux copies run every 8 hours starting at 2:00 AM.
Ken_H
Apprentice
  • December 20, 2021
So … I misunderstood the instructions for Moving a Mount Path which say:
  • The move mount path operation overwrites the destination mount path. Therefore, ensure that the destination mount path is an empty folder.
I mistakenly thought this meant I couldn’t move to one of the existing drives but it turns out that all I needed was to create a new folder.  I created L:\MP4 and was able to move everything off M: to that new folder so I’m in a good position to change the configuration on the M: drive.  Thanks everyone.  @YYZ was correct and I’ll mark their reply as the solution.
Ken
Nikos.Kyrm
Forum|alt.badge.img+16
  • Community All Star
  • April 10, 2025
Hello ​@Ken_H , ​@YYZ and all,
Have an update for Moving a Mount Path operation.
At least in MR 11.36, as per the documentation, mount path consolidation is supported:
https://documentation.commvault.com/2024e/expert/moving_mount_path.html
I also tested moving a used mount path to another active mount path within the same MA. This operation created a new subfolder under the destination path, preventing overwriting or corruption.
Please for your feedback,
Nikos
