where to download media kit older than 11.14 for test
  • Oct 30, 2023 8:59 AM UTC
  • 9 replies
  • 232 views
Hi Community,
We are planning to convert our production environment’s DDBv4 to DDBv5, but in our test environment, all our media agents are in DDBv5. As the DDBv5 comes from the version 11.14, i am searching for a media kit package older than SP14 in order to test and validate.
Is there Anywhere i can download a mediakit older than SP14 which is not available in commvault store ?
Thanks in advance.
Best answer by sauvegarde
Hi@sauvegarde,
I am afraid there is no archive section. Versions older than SP14 cannot be downloaded.
Oh ok… thank you @Javier for the confirmation.
Arunkumar P
Forum|alt.badge.img+9
  • Oct 30, 2023 12:46 PM UTC
@sauvegarde - SP14 is the older service pack and it’s a deprecated one.
I would recommend you to upgrade your environment at least to SP16.
  • Oct 30, 2023 1:21 PM UTC
Hi Arunkumar,
Thank you for the reply, my environment is under 11.28. For the cross test purpose, i would like to install a media agent older than SP14.
Do you know where i can download the package?
Regards
  • Nov 2, 2023 10:11 AM UTC
Hi @sauvegarde ,
No environment should remain on anything lower than one of the supported releases;
> For LTS - SP16, FR20, FR24, 2022E(FR28) or 2023E(FR32)
> For Innovation Releases - 2023(FR30)
If you still run an environment on anything older, we strongly suggest to upgrade it to a supported version.
Could you provide further details of which test will require an MA on a version over 5 years old please?
  • Nov 3, 2023 8:50 AM UTC
Hi @Javier,
thank you for your inputs.
In our production environnement, i ran the workflow “ConvertDDBv5” and it says some of our DDB requires and upgrade. For that, i have to do the perfomance test in a testing environment hence i need an old version just for testing purpose.
Also we would like to compare the performance of a DDBv4 and DDBv5, with and without garbage collection option.
Thank you
  • Nov 6, 2023 8:07 AM UTC
Thank you for giving us further insights @sauvegarde
As previously mentioned, any version older that FR30 or the supported LTS releases, is considered EOL and therefore should not be taking into account when comparing features/performance.
  • Nov 6, 2023 9:01 AM UTC
Thank you @Javier.
I understand that, but i want to know is there any software archive section where i can download the older versions?
Thank you
Best Regards
  • Nov 6, 2023 11:55 AM UTC
Hi @sauvegarde,
  • Nov 6, 2023 3:53 PM UTC
Hi@sauvegarde,
  • Nov 6, 2023 3:56 PM UTC
Sorry i have clicked “Best Answer” on my message by mistake which i cannot change.
