we just fix one of our media server that went into Dedup DB Reconstruction and now another one
this always happen after Disaster Recovery Backup what is happen ?
Best answer by jgeorges
View originalwe just fix one of our media server that went into Dedup DB Reconstruction and now another one
View originalHey
To confirm, when you say DR Backup, we’re referring to the Commserve DB Backup? If so, this is definitely unusual. BUT if we’re referring to the DDB Backup, than this could be something related to the VSS Process which may require a little more digging.
Either way, definitely worth raising a support case, however here are some fundamentals that might help identify the root cause:
I’d start by checking the SIDBEngine log around the time of the last shut down/reboot.
Find the current Process ID (its the first from the left OR can be found in Process Manager), scroll to the TOP of the log file and search down for that PID.
We don’t actually want to look at the current PID, but this gets us to the last moments before previous PID went down, and should let us see if the process was gracefully stopped before the power down/service cycle OR if it closed out abrubtly.
There are a few caveats to the log review above;
If you do log the ticket out, let me know here and we’ll take a look for you.
Cheers,
Jase
Hey
Cheers,
Jase
Hi @jgeorges,
I have one query that does Commserve DB contain information of deduplication databases of Media agent?
Thanks.
Hello
The CommServe indeed tracks some details of every deduplication store and if those differ between the CommServe DB and MediaAgent, the DDB is pushed into reconstruction.
This also happend when you do a CommServe Recovery Tool action or unplanned failover using livesync and other scenarios as outlined by
Mike
