Why seal Cloud based DDBs?
  • 13 June 2022
  • 397 views
Badge +12
Hi All,
Came across this thread, and all the replies were very helpful, had another question regarding DDB sealing.
Why do we need to seal the DDB when using Cloud library ? And can we defer its execution as far back as possible ?
Kind regards.
Best answer by Matt Medvedeff 13 June 2022, 16:22
Badge +10
You don’t always have to seal the DDB when using a Cloud Library. What it really boils down to is whether the Storage supports Micro-pruning.  See the documentation here for which providers and storage tiers support it - https://documentation.commvault.com/11.24/essential/9236_supported_cloud_storage_products.html
For more details on pruning and DDB sealing for Storage that does not support Micro pruning see here -
https://documentation.commvault.com/11.24/expert/9267_data_pruning_from_archive_cloud_storage.html
Let me know if you have any questions
Badge +12
Thanks a lot, Matt,
Our storage is a S3 Compatible Storage, and is listed under the link below :
https://documentation.commvault.com/11.24/essential/9237_supported_cloud_storage_s3_compatible_object_storage_vendors.html
So my guess is that our storage supports Micro-Pruning. Which also means, that we do not have to seal our DDB ?
Correct me if I am wrong.
Kind regards.
Badge +10
Confirmed, you do not have to regularly seal the DDB for S3 Compatible.
Badge +12
Thanks a lot @Matt Medvedeff for your guidance, much appreciated.
