a customer asked if it would be possible to make all their primary copies (for disk libraries) WORM-protected and what the implications were.
Up until now our standard is n-days/1cycle retention on primary copies and n-days/0cycle retention on a secondary copy.
We basically use the 1 cycle as a safety net. So if for whatever reason the backup of a client does not work for a long time, they always have one backup available without setting a manual retention on those jobs.
Now we have an internal discussion about how the retention for WORM works. Specifically if the cycle retention is also relevant for manual deletion of the jobs/clients that hold those jobs.
So for example: A client is using a WORM storage policy with 14 days/1 cycle retention.
Data Aging will not age out and delete the jobs automatically until both conditions are met.
But is it possible to manually delete the jobs on day 15? I would say it is not possible because it is still retained by the cycles. If that is the case, backups of long gone machines would always remain.
So it would be a decision between keeping a cycle as safety net or WORM.
In the documentation it is not completely clear what the case is and I don’t want to test the thing since we’d need support to remove the test afterwards.
If anyone has any experience or can point me to a page in the documentation I have overlooked I’d be grateful.
Thank you and have a nice day everyone!
Jakob
Best answer by Collin Harper
