/ws/ddb and /opt/commvault/MediaAgent64/IndexCache are not mounted anymore after the faulty SSD replacement
  • March 31, 2023
  • 104 views
SSD has been replaced
Node has been rebooted once
the entry is in the /etc/fstab
Best answer by Emils
Depending on which Hyperscale you’re running (1.5 or X) these steps may differ:
https://documentation.commvault.com/v11/expert/104154_replacing_metadata_drive.html
I would high recommend reaching out to support for help if the above does not help.
Emils
  • April 3, 2023
  • April 3, 2023
issue has been resolved
thanks for the suggestion
