Block Level Backup Options-Optimize for Table Level Restore.
  • February 16, 2023
  • 451 views
FeRox
Novice
Dear Sirs, please help me: In SQL databases more exactly in Properties-Advanced Options- Block Level Backup Options-Optimize for Table Level Restore.
Does this option work for backups that are on tape or does it only apply to disk? What is the impact of activating this option?
Thank For Your Help.
(attached image)
Best answer by Scott Reynolds
Hello @FeRox
No it is not supported for tape/virtual libraries.
When this option is enabled full databases backups will leverage VSS to perform the backup. It does allow table level recovery and in some situations like Sharepoint mining it makes sense but in general there is no reason to enable this unless you have those two above requirements. More info is listed here:
https://documentation.commvault.com/2022e/expert/18230_performing_block_level_backup_operation_on_sql_databases.html
Hello @FeRox
FeRox
Novice
  • February 23, 2023
Dear friends, I have another question, why when the block level is activated, the backups are executed by a single stream, and this is already a problem because it degrades the speed of the backups.
@FeRox Correct that is expected as block-level backups leverage VSS which is restricted to 1 stream.
FeRox
Novice
  • February 23, 2023
Does this happen in all commvault versions, as this degrades the transfer speed too much.
@FeRox Yes it would apply to all versions.
Believe the limitations here is the VSS writer
https://learn.microsoft.com/en-us/sql/relational-databases/backup-restore/sql-server-vss-writer-backup-guide?view=sql-server-ver16
