Data reader of each subclient
  • September 8, 2023
  • 180 views
EJIE
Novice
Forum|alt.badge.img+5
Hello good,
I would like to know if there is any way to know the # data reader of each subclient configured in Virtual Machines backup, either through a report, query, etc.
To determine the load of the storage libraries by subclient and their programming in order to avoid saturation of jobs and resources.
Thank you,
Regards.
Best answer by Sebastien Merluzzi
Hi @EJIE
The Commcell Configuration Report will give you that info:
Sebastien
Hi @EJIE
Sebastien
EJIE
Novice
  • September 11, 2023
Hi Sebastien!,
Yes, That's what I wanted to see, thank you very much.
Regards.
