Hi All,
I am using Kubernetes Openshift. When Im trying backup some namesapces fails. as the following. THe applications are up and working fine.
Hi All,
Hi
What version are you using?
Can you check vsbkp.log on the VSA?
Sebastien
Hello
COmmvault version 11.28.63
I have checked the logs
21664 17c 08/17 20:42:03 24151442 K8sApp::DeleteSnapshot() - Snapshot [gbh-services-prod][gbh-services-prod-cv-24151442] deleted
21664 17c 08/17 20:42:03 24151442 CK8sInfo::MountVM() - Backup failed for app [gbh-services-prod]. Error [1002:0xEDDD03EA:{CK8sInfo::Backup(438)} + {K8sApp::CreateWorker(1817)/Int.1002.0x3EA-Error creating worker pod. [0xFFFFFFFF:{K8sUtils::WaitForReady(1546)/ErrNo.-1.(Unknown error)-Wait timedout for [g]. Last update [{"conditions":[{"lastTransitionTime":"2023-08-17T17:35:30Z","status":"True","type":"Initialized"},{"lastTransitionTime":"2023-08-17T17:35:30Z","message":"containers with unready status: [cvcontainer]","reason":"ContainersNotReady","status":"False","type":"Ready"},{"lastTransitionTime":"2023-08-17T17:35:30Z","message":"containers with unready status: [cvcontainer]","reason":"ContainersNotReady","status":"False","type":"ContainersReady"},{"lastTransitionTime":"2023-08-17T17:35:30Z","status":"True","type":"PodScheduled"}],"containerStatuses":[{"image":"centos:8","imageID":"","lastState":{},"name":"cvcontainer","ready":false,"restartCount":0,"started":false,"state":{"waiting":{"reason":"ContainerCreating"}}}],"hostIP":"10.175.34.44","phase":"Pending","qosClass":"Burstable","startTime":"2023-08-17T17:35:30Z"}]}]}]
21664 17c 08/17 20:42:03 24151442 CheckVMInfoError() - VM [gbh-services-prod] Failed to create Worker Pod.
Hello
From the errors in the logs, while creating the worker pod it seems to be giving a time out error and this could be because of an issue while pulling the image from the repository.
We would recommend to upgrade VSA to latest MR as it contains fix for similar issue.
Tanuj Balani
