Nutanix Mine with Commvault OVA missing from Store
Badge +1
Hello everyone,
About to do a Mine with Commvault deployment, in the documentation it says to download the Mine plug-in from the Commvault store but it is missing:
https://cloud.commvault.com/webconsole/softwarestore/store.do#!/133/724?fl=%7B%22qfType%22:1,%22qfVal%22:%22%22%7D
Does anyone know where to get it?
Badge +15
@rockstershine
I see this:
I clicked on the hyperlink from this article: https://documentation.commvault.com/2022e/essential/144802_downloading_commvault_plug_in_for_nutanix_mine.html
I’d use the FR24 template, it says this:
So you can just patch the latest feature release/maintenance release on top.
Let me know if your issue is that the files aren’t there and I’ll see what I can do..
Regards
Chris
Badge +1
@rockstershine
I see this:
Regards
Chris
Hey Chris,
Thanks for the reply. I have uploaded the .qcow2 image to the Nutanix cluster, but when powering on the VM, I get a Linux server:
The documentation, however, says that:
“The VM console opens and a powershell command executes.”
Kind regards
