Hi!
We are in the middle of PoC with potential new customer and we ran into a problem with P2V to Hyper-V VM.
Error message:
Error Code: [19:1616]
Description: Virtual Machine Management job has failed because Refresh is not done for Virtualization client :[HYV-CL.company.com]. Please do refresh operation for this virtualization client.
Source: CV, Process: VMManagement
VMManagement.log:
10136 3888 08/31 11:20:46 ### Init() - Initializing job control [token=,cn=CV], serverName [CV.company.com], ControlFlag [1], Job Id [671]
10136 3888 08/31 11:20:47 ### DBBase-SQL() - dbmethods.cpp:1431, DB Layer will use [Exec] access by default. Use SetAdminAccess API for on demand Admin access.
10136 3888 08/31 11:20:47 ### Cvcl::init() - CVCL: Running in FIPS Mode
10136 3888 08/31 11:20:47 ### DetectNativeClient() - Found reg key [SOFTWARE\Microsoft\Microsoft SQL Server\SQLNCLI11]. Using driver [SQL Server Native Client 11.0].
10136 3888 08/31 11:20:49 ### CVJobCtrlLog::registerProcess(): successfully created file [C:\Program Files\Commvault\ContentStore\Base\JobControl\10.136]
10136 3888 08/31 11:20:49 671 #############################
10136 3888 08/31 11:20:49 671 # VM Management Job Started #
10136 3888 08/31 11:20:49 671 TaskInterfaceDB::getOptions() - Loading default options into memory
10136 3888 08/31 11:20:49 671 VmAuxOps::getClientIdAndInstanceIdFromClientName() - Failed to fetch virtualization client id from application table for the client name [HYV-CL.company.com], error[64]
10136 3888 08/31 11:20:49 671 VmAuxOps::fetchVCenterCredentials() - Trying for datacenter refresh for this client as it's a VirtualizeMe job.
10136 3888 08/31 11:20:49 671 VmAuxOps::fetchVCenterCredentials() - Failed to fetch instance Id from Virtualization Client [HYV-CL.company.com], error[64]
10136 3888 08/31 11:20:49 671 fetchVCenterCredentials failed. Error [64]
10136 3888 08/31 11:20:49 671 Updating credentials in VM Request failed
10136 3888 08/31 11:20:49 671 ###############################################
10136 3888 08/31 11:20:49 671 # VM Mananagement - Provision VM Phase Failed #
10136 3888 08/31 11:20:49 671 COMPLETE CALLED (PHASE Status::FAIL), Job ID = 671
10136 2e68 08/31 11:20:49 671 CVJobCtrlLog::unregisterProcess(): successfully removed file [C:\Program Files\Commvault\ContentStore\Base\JobControl\10.136]
Refreshing Hyper-V Datacenter won’t help.
I am not much of a Hyper-V guy, so I am kindly asking you guys for help. Any idea?
Best answer by euMike
