Error Code: [82:156] Description: The job is pending because: The destination encountered an error while processing the data from the source. Source: com-v, Process: CVD
VM backup issue
Best answer by Gil S
Hi
Have there been any recent Commvault software updates to your Commserve or media agents and or vsa proxies? You might want to check that the media agents and vsa proxies are on the same Commvault Software Version level as your Commserve.
