We are having a problem with our Netbackup setup with HotAdd mode to backup our VMware, i.e. if the Proxy Server takes more than 4 VMs to backup at the same time, loads of VMs would fail with the below error messages.
“Error opening the snapshot disks using given transport mode: hotadd Status 23”
In other words, this Proxy Server can backup no more than 4 VMs at the same time.
OK, I admit that this is a problem in our Netbackup environment but I feel that I may get some help by posting this question here in Commvault forum because
- Firstly, the reason why we are testing this HotAdd transport mode within Netbackup environment is because we intend to deploy the same technology in the coming months in our another backup environment which is Commvault.
- Also, at the moment, the Netbackup support seems to be at their wits’ end (which does make me feel a bit disappointed). But, on the other hand, the issue seems to be more connected to the VMware environment and its associated configuration / setup of the Proxy Server rather than the backup software itself. In other words, the problem could be commonly and widely known by all the major backup vendors.
- Last but not least, you guys on this forum do have a much quicker and more informative response, to be honest.
So, if your guys are still happy for me to continue, then I’ll give you the details of our environment
- Number of datacentre: 1
- Datacenter vSphere version: 6.7
- The version of ESXi Server hosting the Proxy Server: 6.7
- Datastore hosting the Proxy Server and other VMs: VMFS 6
- Total number of VMs to backup: 560
The configuration of the VMware backup Proxy Server
- OS: Windows 2019
- MEM: 32 GB
- CPU: 16 cores
- Local disks: C (100GB with 68GB free) and D (40GB with 35 GB free)
- The size of the datastore hosting this proxy Server: 4TB with 950GB free
- The number of SCSI cards: 4
- The type of SCSI cards: VMware Paravirtual
- The VDDK version (embedded within the Netbackup): 6.7.3
- PCI device: 1 passing through PCI which is zoned with a tape library
Just to summarise, this VMware Proxy Server is also a Netbackup Media Server, which reads data directly from its HotAdd mounted VMDK, and then writes data directly to the FC connected tape library.
My observation is
- During the backup, even with simultaneously backup VMs to be set at 16, the CPU and MEM would hardly be stressed.
- However, from its disk management GUI, with a setting of more than 4 VMs to backup at the same time, it would constantly scanning the SCSI cards to mount/unmount those VM’s VMDK disks, which would freeze the Proxy Server. In fact, the more VMs to backup at the same time, the busier its SCSI cards would be, which makes me wonder if this is the root cause of the problem ?
Has anyone seen the similar issue under a Commvault environment with a CommVault Proxy Server setup in this way ?
Many thanks,
Kelvin
