Amount of VSAs
  • October 27, 2023
  • 8 replies
  • 296 views
antonio
Explorer
Hello everyone,
We have an environment that consists of more than 100 VMs with a significant amount in TB in total. Analyzing the documentation https://documentation.commvault.com/2023e/expert/1661_hardware_specifications_for_virtual_server_agent.html, it only informs the sizing of the VSA and its capacity for FET.
We have implemented 1 VSA with the Medium specification, however, when running some Jobs, we noticed that only 5 VMs at a time are executed and this is the number of Data Readers for VMs Groups for all hypervisors standard, as mentioned in the documentation: https://documentation.commvault.com/2023/essential/107675_default_number_of_data_readers_for_vm_groups.html
Also, the transport mode is mixed, some VMs are using nbd others are using hotadd.
Because of this, we are concerned that the backups of this environment will take too long to protect the entire environment. So, thinking about this scenario, I was left with doubts about the number of VSAs needed to implement in the environment, in addition to its Sizing.
Note: We only have 1 MediaAgent at the moment, based on what is also stated in the documentation about its Sizing.
Antonio.
Forum|alt.badge.img+5
Hi @antonio ,
Please check the below documentation, which might be helpful for you. You might need to increase the SCSI controller and VSA here as you are running a concurrent backup job with more than 15 disks.
HotAdd Transport for VMware (commvault.com)
Keshika Bisht
  • October 30, 2023
@antonio ,
Thank you for reaching out.
Could you please update for the below questions.
How you are taking backups of the 100VMs,
Individual VMs or Datastore level or Cluster Level.
if you are trying to take 100VMs under single subclient and wanted to take backups are the same time, I would suggest you to increase the number of VSAs. There is no specified number which commvault suggests because it depends on environment to environment.
For increasing performance you can segregate the VM into multiple subclients and change their schedules.
For data readers options yes you can increase the number of readers too but if you are having only 1 VSA it can effect the performance.
The Transport mode depends on the configurations and permissions you have given. So to know why the VMs are using different transport mode, kindly check below documentation.
https://documentation.commvault.com/2023e/expert/32037_transport_modes_for_vmware.html
antonio
Explorer
  • October 30, 2023
Hello @nishas,
Answering your questions:
  • We are taking individual VMs backups with the intention of using subclients to be able to protect these VMs;
  • As we are thinking in use more subclients, we also have the intention of use different schedules;
  • Implementing more VSAs are also something we are planning, and we want to use LAN Free backups using hotadd transport mode, to minimize the time and use of the resources;
We don't intend to increase the number of data readers to such an exaggerated number, with the idea of using 10 to 15 data readers, and if we notice good performance, we'll keep that number.
Antonio.
  • October 30, 2023
@antonio
Sure, thanks for update.
Taking backup of individual VMs will be helpfully to segragate the subclients.
The intention to increase the Data readers is to find out if single VSA can hold that backups for 100VMs.
Do update how it goes.
Onno van den Berg
Forum|alt.badge.img+24
Assuming you are referring to a VMware environment than I would indeed scale-out the amount of access nodes. You can adopt the FREL for this to make life easier and deploy them directly from Command Center. For the actual configuration I would strongly consider adopting protection plans. In case this is AWS than I would look into adopting the scale-out architecture.
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • October 31, 2023
Hi @antonio
Looks like you are on track and you already received some good tips.
Facing 100+ VM's I would indeed adopt a LAN free method if possible to offload certain aspects.
I would, if HotAdd is the choice, introduce more VSA's, even if it is only to provide a HA implementation of the VSA (Performance wise preferred as well). Then you can put all VSA's in a Client Group and set that group in your Hypervisor Access node list and remove individual nodes, easier to manage 🙂
Ideally one per host so you prevent inter-host traffic, assuming you are using an on-premise hypervisor.
  • October 31, 2023
Are you using incremental and synthetic full backups? - can you meet backup SLA’s with incrementals today?
antonio
Explorer
  • October 31, 2023
Hi guys, thank all for the good tips and the help so far.
@Onno van den Berg yes, we are in a VMware environment. With your experience, using FREL as access node and VSA, is the performance good? I think using FREL could be a good way out from this customer specially about licensing O.S. in his environment.
@Jos Meijer that’s a good idea! 😀 I think that creating a Client Group can be very helpful to manage and make the things more easier
@Damian Andre Yes, we are using incremental and synthetic full backups. As we are making adjustments in the environment, we haven’t all the workload fully protected yet, the SLA is missing in this moment.
