we have many vCloud Hypervisor in our environment.
We have one Master Org Hypervisor and all other vCloud Hypervisor are created with “Create Org Account” then it is referenced to the master.
For some reason, I dont know why, 3 of our vCloud Hypervisors lost the reference to the Master Org Hypervisor and backup was not running anymore.
I found no way to reconnect the vCloud Hypervisors to the Org Master. Workaround solution was to create Hypervisor new with other name and during creation you can connect to Master.
So my question is, is there a possibility to recreate the connection to the Org Master vCloud for existing vCloud Hypervisor. So I only found it when you create a new one. Editing is for this not possible. Via API I did not found anything which is working.
Thanks & BR
Marcel
