Creating pseudo-client for RHEV (http vs https)
Kamil W
Commvault Certified Expert
  • Commvault Certified Expert
  • 83 replies
Hi Guys,
I am creating the RHEV pseudo-client with the Customer.
We have noticed that during creating RHEV pseudo-client, Commvault uses port 80 (http) to comunicate with RHEV Manager.
Port 80 (http) is blocked by the firewall. They use only https (port 443) in the environment due to some safety restrictions.
Is any way to force Commvault (VSA) to use port 443 during creating RHEV pseudo-client?
Rgds,
Kamil
Best answer by Aplynx
Kamil,
With 24.7 installed, that would include hotfix 3030 (part of 24.2). If this is also installed on the proxy\access nodes for RHEV, when the initial denial happens on port 80 (http) a certificate should be generated either way and retried on port 443 (https). If 24.7 is on the proxies and weโ€™re not seeing this behavior, please open a support incident for review.
MichaelCapon
Hello @Kamil W ,
What version of Commvault FR and MR are you using here please?
The reason for asking is that some recent MRโ€™s include a patch to resolve the configuration issue when Port 80 is blocked:
Maintenance Release 11.24.2
Maintenance Release 11.23.17
Maintenance Release 11.22.32
Michael
Kamil W
  • 83 replies
  • October 5, 2021
Hi @MichaelCapon ,
Itโ€™s definitely FR20. Iโ€™ll ask the Customer about version of Maintenance Release.
Iโ€™ll let you know ASAP.
Rgds,
Kamil
Kamil W
  • 83 replies
  • October 6, 2021
Hi again,
CS is running 11.20.67
I cannot see any mention about the issue for FR20.
https://documentation.commvault.com/11.22/assets/service_pack/updates/11_20_67.htm
Any ideas?
Rgds,
Kamil
MichaelCapon
Hi @Kamil W ,
I am checking this and will get back to you.
Michael
Kamil W
  • 83 replies
  • October 7, 2021
@MichaelCapon  Sure, I am looking forward to any news from you.
Rgds,
Kamil
MichaelCapon
Hi @Kamil W,
If your customer does not have any plans to move to the above stated versions, can you raise a case with Support? - We may be able to request this for back port to FR20.
Thanks & Kind Regards,
Michael
Kamil W
  • 83 replies
  • October 7, 2021
@MichaelCapon  Many thanks!
The Customer decided to upgrade CS to 11.22.45
Iโ€™ll let you know, how it goes ASAP.
Rgds,
Kamil
Forum|alt.badge.img+23
Hey @Kamil W , gentle follow up on this one.  any word from your customer?
Kamil W
  • 83 replies
  • October 15, 2021
Hi @Mike Struening !
Yes, I had a remote session with the Customer yesterday.
They upgraded CS to 11.24.7. However, once port 80 is blocked, backup of RHEV is not working.
It seems like port 80 is needed to initiate the connection, then Commvault is already using port 443 to backup the data. Thatโ€™s what they see in the Firewall GUI.
Any ideas how to resolve this issue? They need to use port 443 (https) due to some safety policys.
Rgds,
Kamil
Aplynx
Forum|alt.badge.img+13
  • 291 replies
  • October 15, 2021
Kamil,
Kamil W
  • 83 replies
  • October 18, 2021
Hi @Aplynx ,
Many thanks for your reply.
As I remember VSA is running 11.20.x.
Once the Customer updates VSA Proxy, Iโ€™ll let you know how it goes.
Rgds,
Kamil
Hi @Kamil W , following up to see if the customer has updated the proxy yet.
Kamil W
  • 83 replies
  • November 8, 2021
Hi guys!
The customer has finally upgrated the proxy. Everythingโ€™s working as expected now.
Thank you for your help!
Rgds,
Kamil
Sweet, thanks for the update!!
  • 143 replies
  • October 24, 2022
Good Morning Commvault Community,
The client encountered a similar problem but for the SP20 version. Do you have information, is there any fix for this version or do we need to contact CV support to write a new fix for SP20?
Thanks&Regards,
Kamil
Confirming @Kamil created another thread for this.
  • 143 replies
  • November 15, 2022
A fix has been released, has been tested and works as described. OLVM communicated with commvault on port 443 after deploying this fix.
I don't know if I can share it and I don't know if it will be available in the official MR version, but if anyone needs it, they know where to find me ;)
Thanks for help @Mike Struening
Kind Regards,
Kamil
@Kamil give me the patch name or form ID and Iโ€™ll find out.
Thanks, man!
Cookie policy
Cookie settings
