CVVD.sys crash on 11.20
  • February 15, 2022
  • 147 views
I’m on 11.20.85 and had a media agent/ VSA proxy reboot when doing restores. Due to the size of the restore (600 GB+), I restored the files to the proxy instead of going straight to the VM. The crash dump says: Probably caused by : CVVD.sys ( CVVD+d01b )
Is this a different issue since 11.20 isn’t a version listed to have problems?
@skipreily , potentially unrelated, though to be sure, I’d open a case with support.  11.20 is not listed in the affected range, though we should get a through investigation going.
Share the case number here once you do!
  • February 16, 2022
Here is the case number, 220216-613 @Mike Struening
Thanks.
Great!  I’ll split this into its own thread.
