Delete old backups from servers
  • February 27, 2023
  • 936 views
How to make sure that CommCell delete the old backups ?
I am running CommServe v 11:28:19
Best answer by Orazan
I would recommend first investigating the reason that jobs are not aging.  In the CommCell console, you can run a report called the Data Retention Forecast and Compliance report.  You can run it against an individual storage policy or a library.  You will see a column that lists the reason that each job is held in retention.
Forum|alt.badge.img+18
  • February 27, 2023
Can you please provide more information?  Are you wanting to delete all backups?  Delete some backups?  Are the backups on Tape, Disk, Cloud?
  • February 27, 2023
Backups on disks on the server and it is supposed to be deleted by CommCell as they are old and retentiontio set to 30 days
  • February 27, 2023
  • February 28, 2023
It will be done, but my main question is, why are these old backups still available? CoomCell should only keep the latest backups when nothing has changed.
  • February 28, 2023
There are rules for retention.  The report mentioned will tell you why each job is being held past retention.
