I've had multiple instances of duplicate client computers showing in the Comcell Console when using an In-Guest agent and then later including the VM for backup.
Whilst I know (and have successfully) merged clients to remove the duplicates i would like to understand how Commvault decides when a discovered VM is the same as a client that is already discovered/configured for backup in a different way (ie with an installed agent in the guest).
Thanks in advance.
