Error Code: [91:115] Description: Unable to attach disks to virtual machine
  • October 9, 2024
  • 217 views
We are restoring the Physical server to Azure using Virtualize me option. During the restoration we are getting below error message. Could someone please help me to fix the issue.
Mohamed Ramadan
Explorer
hello @SSP
According to the log, there is a communication error with the Azure machine on port 8400.
Could you please try using telnet or the cvping tool to check the connection?
Mohamed Ramadan
Data Protection Specialist
  • October 9, 2024
@Mohamed Ramadan Thanks for quick replay.
we have fixed the communication error, still we are getting the same error message.
attached log for reference
Mohamed Ramadan
Explorer
hello @SSP
please review the Commvault Requirements and Azure VM Requirements.
https://documentation.commvault.com/2024/essential/attaching_disk_to_azure_vm.html
Additionally, If you're using an IAM VM role, could you please check if the access node has the rights to write to the Azure VM, edit the machine configuration, and restore disks that are not limited by the Azure disk restore requirements?
Mohamed Ramadan
