Error creating virtual machine snapshot. Error Code: [19:857]
  • April 10, 2022
  • 9748 views
I’m trying to backup a virtual server but I got the following error.
Description: Error creating virtual machine snapshot. The operation is not allowed in the current state of the host. Snapshot creation attempt took [00:00:01]
Check readiness show no Issue.
The error in vsbkp.log:
NOTE: all other virtual server backups work fine
Best answer by Stuart Painter
Hi @Mostafa Amin
Thank you for the question.
The error indicates that Commvault requesting the VMware to take a snapshot of the VM, but VMware is declining to perform the snapshot.
This could be because the VMware ESX host is in maintenance mode.
Case history here at Commvault does show some cases where the maintenance mode activity became stuck on the ESX host and this needed to be resolved in VMware before successful backups could be taken.
Please check the status of the ESX host and see if that reveals anything.
Stuart
Hi @Mostafa Amin
Stuart
