Issue connecting vCenter to Commvault
  • Jul 10, 2023 3:11 PM UTC
  • 1199 views
I have a fresh installation of Commvault version 11.28.56. I am attempting to connect to our vCenter instance through the Command Center GUI. After putting in the information to ‘Add Hypervisor’ I receive a ‘Request body is empty or format is invalid.’ error. Clicking equivalent API shows the following:
  "vcenterHostName": "172.16.123.10",
  "name": "vCenter",
  "accessNodes": [
      "id": 2,
      "name": "n1-prod-commvlt"
  "userName": "vsphere.local\\administrator",
  "password": "cGFzc3dvcmQ=",
  "hypervisorType": "VMware",
  "skipCredentialValidation": false
Attached is the error. I have tried vsphere.local\administrator, administrator@vsphere.local, and a Windows AD account. I ensured the ‘VSA’ software was installed on the access node. Any help is appreciated!
Error
Best answer by Rajiv
Hello @JWalker
The “Request body is empty or format is invalid" error is a known issue between 11.28.56 and 11.28.62 (inclusive).
The error occurs when you are trying to add a VMware Hypervisor through Command Center. This issue is resolved in 11.28.63 and later under hotfix 4436. The fix needs to be applied to your web server hosting Command Center (typically the Commserve).
If you cannot upgrade at the moment, as Pedro suggested, please use commcell console.
Best,
Rajiv Singal
PedroRocha
Apprentice
  • Jul 10, 2023 7:51 PM UTC
Hello my friend,
Did you try to add the vcenter through the Commcell Console?
I've seen this error before and I remember that through Commcell Console, the error was more helpful.
Is there any firewall between access node and vCenter?
Pedro
Rajiv
  • Jul 11, 2023 6:45 AM UTC
Hello @JWalker
Best,
Rajiv Singal
  • Jul 11, 2023 12:39 PM UTC
Thank you, Rajiv and Pedro!
