multiple backup sets
  • March 30, 2023
  • 8 replies
  • 106 views
Hello all
I have multiple Backup sets I want to create a rule on the backup set level to make sure that for example VM that is a member of backup sets does not belong to others
is that possible?
Hi Ayman_Seyam,
Please check this https://documentation.commvault.com/v11/expert/62269_backup_set_property_vm_filters.html
Let us know if this works for you
  • March 30, 2023
Hi Ayman_Seyam,
I need a rule that says { VM in Backup set 1 excluded from other backup sets } no manually exclude VM one by one from others backup sets
@Ayman_Seyam not sure this is something that can be automated.
Its an unusual request normally you create additional backsets so that you can have the same content.
Can I ask what is the end goal you are attempting to achieve?
  • March 30, 2023
@Ayman_Seyamnot sure this is something that can be automated.
I have a large number of VMs ( up to 4K) and there is an individual subclient for each one so the performance is very very low when I browse that backup set that’s why I’m thinking to create separate backup sets
Hi @Ayman_Seyam ,
Can you check our Best Practice and see the best option:
https://documentation.commvault.com/2022e/expert/32572_best_practices_for_virtual_server_agent_with_vmware.html
Sebastien
  • April 5, 2023
Hi @Ayman_Seyam ,
Sebastien
not related to the issue
Hi @Ayman_Seyam ,
Why don’t you Browse at the VM level instead?
  • April 5, 2023
Hi @Ayman_Seyam ,
I want to a rule that says skip VMs taken from set1 from other sets
