HI Team, can someone advice the error below? why i encounter this recently? I running the Backup Copy from secondary snap copy to primary backup copy.
OS mount failed : [VMWare Mount snapshot failed [0xEC02ECC3:{VMwareSnapOSUtil::MountSnap(2007)/MM.60611-Error mounting the snapshot LUNs because there are multiple copies present.}] (MM.60611)]
Source: adr-ma-001, Process: vsbkpOS mount failed : [VMWare Mount snapshot failed [0xEC02ECC3:{VMwareSnapOSUtil::MountSnap(2007)/MM.60611-Error mounting the snapshot LUNs because there are multiple copies present.}] (MM.60611)]
Primary Backup Copy fail and encounter error VMWare Mount snapshot failed
Best answer by Raj Balaraj
I have run the schedule by change the reader from maximum to 1 at a time at schedule advance setting and i have 0 error. Thanks :)
