Registry-Key - s3dfsRootDir
  • October 30, 2023
  • 192 views
Good Day @everyone,
quick question,
we’re trying to move the s3dfsRootDir for Live Mount Operations to a dedicated drive.
When Specifying the key: https://documentation.commvault.com/additionalsetting/details?name=s3dfsRootDir
as an additional setting to the Mediaagent, we are not able to specify the location. If we put a value like D:\3dfscache into the key, the GUI displays, that the string is outside of the dictionary values. So I left the value “string”… But I am completely unsure where to define the actual location.
Does someone struggle this behaviour?
Best regards
Best answer by D4T4Pr0T3ction
Good Morning all,
since the regkey did not work for us (didnt restart Services).
We trialed and errored as well.
Finally we’re using the “File Server” Tab on the Mediaagent-Properties to have the VM restored into E:\3dfscache. AFTER Recylcling the Services on the Mediaagent the next VM-Life Recovery will use this cache….
  • October 31, 2023
Hi @D4T4Pr0T3ction ,
the additional setting is for “ The Live Mount feature uses a 3DFS cache on the MediaAgent that performs the Live Mount. By default, the 3DFS cache is located in the Job Results folder for the MediaAgent; but you can use this additional setting to specify a different path for the cache.”
You can add the additional setting from the media agent propertis as shown below,
note: Make sure D:\3dfscache is present
  • October 31, 2023
Hi @SMD ,
Tyvm for your help.
Although defined as an additional setting and presence of the key in the MA registry, the path seems not to be utilized.
Right one is C$ which is still used for the restore.
Any Ideas?
  • October 31, 2023
Hi @SMD ,
Tyvm for your help.
Any Ideas?
UNC/SMB path wont be supported and kind of defeats the purpose of a having a fast location - latency matters with this type of operation
  • October 31, 2023
@Damian Andre
The Screenshot was just to clarify, that this path (which is accessible for users via UNC) is not used.
However,
i put out the key and filled in the value of the 3dfsCache-Directory in the MA Property Tab “File Server”.
This seems to work now.
Michael Woodward
Certified Expert
Hi @SMD ,
Tyvm for your help.
Any Ideas?
One thing you will need to do after using this key is a Service Restart on the MediaAgent, if you don’t do this it will keep using the default location of the JobResults directory.
I found this out by a bit of trial and error.
@Damian Andre  perhaps this Additional Setting description needs to be updated?
  • December 8, 2023
Good Morning all,
