VCSA Backip failed - VDDK version too low
  • July 29, 2021
  • 7 replies
  • 1563 views
Philipp
Novice
Hallo CV community,
recently we got this error while using the SAN transport mode with auto scheduled jobs.
Failure Reason:
·  ERROR CODE [72:106]: VDDK Version 6.5 is required to back up virtual machines on hosts running ESX 6.5 using SAN mode. The VDDK will be auto updated on the next attempt.
We are using
VMware vCenter Server
Version:
7.0.2.00200
Build-Nummer
17958471
Any ideas regarding this issues.
BR
Philipp
Best answer by Philipp
All machine were backup successfully - after the themselves the VDDK version.
Seams to be OK right now.
Thanks all for your reply's.
BR
Philipp
  • Challenger
  • July 29, 2021
Hi @Philipp !
What’s your current Commvault version ?
Then check through this link for the VDDK / VCenter server version VS Commvault
https://documentation.commvault.com/commvault/v11/article?p=3368.htm
If your VCenter is in v7, are the ESXs hosts also in the same version, or stil in older version?
HI Philipp,
Also, check on the VSA Proxy(ies) you do not have the below registry key configured at a lower version:
Seb
Philipp
Novice
  • July 29, 2021
Hi Seb,
thanks - i checked that - it was not Enabled but i removed that key right now.
Also i disabled the last key in this picture regarding the vStorageTransportMode.
Best regards
Philipp
now:
Philipp
Novice
  • July 29, 2021
Hi @Laurent
→ All ESXi Hosts are 6.5 latested version
Commvault should auto-select the correct version of VDDK depending on the vCenter version you are connecting to. Does the VSA proxy have the correct feature release version on it? almost sounds like it was an older install which has not been patched.
Also, check the registry of the client itself, just in case some legacy / manually input keys are still around.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\CommVault Systems\Galaxy\Instance001\VirtualServer
Philipp
Novice
  • July 30, 2021
BR
Philipp
Excellent.
