VM Restore using "attach disk to VM" - EQUIVALENT API
  • June 27, 2025
  • 87 views
Hi, I am trying to restore a vmdk and attach it to the VM. Was able to do it successfully on the web console.  I also downloaded the EQUIVALENT API.
How do I use the “EQUIVALENT API” for future restores  without using the web console ?
I (preferably) want to use REST, but I couldn’t find the endpoint to run this restore. Does anybody know what the endpoint is ? Thanks in adavance!
sbhatia
Forum|alt.badge.img+9
  • June 27, 2025
You can automate VMDK restore and attach using Commvault’s REST API with the following steps:
1. Get the VM’s client GUID (if you don’t have it) via the GET VM API.
2. Use this REST endpoint to start the restore:
POST <webservice>/v2/vsa/vm/{vmClientGUID}/recover
https://documentation.commvault.com/11.20/rest_api_post_vm_restore.html
Hope this helps!
Hi sbhatia,
Thanks for the pointers, I tried these two endpoint formats already with no luck. both gives 404
https://<webservice>/v2/vsa/vm/{vmClientGUID}/recover
'https://CommandCenterHostName/commandcenter/api/V4/VM/:vmGuid/restore'
I was able to pull the uuid of the vm with this endpoint below, so I know the REST api works, but I am not hitting the right endpoint for the restores
'https://CommandCenterHostName/commandcenter/api/V4/VirtualMachines’
